Check Engine light
Old Apr 2, 2007 | 10:15 PM
s2jigga's Avatar
Default Check Engine light
my check engine light went off today when i was driving, it flashed about 3-4 times, then went out. it just happened tonight, but i was wondering if it has to do with me just going over 60k miles? any thoughts? i was driving about 55mph when it happened and i dont drive my car like crazy either, thanks in advance.
Old Apr 2, 2007 | 11:32 PM
RACER's Avatar
Got oil?
Old Apr 3, 2007 | 12:15 AM
SenderGreen's Avatar
Probably the MRI not the CEL. Oil gets it's own light.
In case it is the MRI.
https://www.s2ki.com/forums/index.php?showtopic=183490
EDIT: I guess using the same logic (one light mistaken for another), it could just as easily have been the oil light. The oil light will flash due to momentary loss of oil pressure. The MRI will flash at intervals unknown to me, based on mileage, before staying on permanently.
Old Apr 3, 2007 | 03:52 AM
silencertk's Avatar
well......
i'd like to think the average person can at least tell a yellow flashing light from a red flashing light.
Since the maintenance light and the CEL are both yellow, its most likely to get them mixed up, especially if you've never seen it on.
In case of it being the maintenance light, it will from now on flash every time you start your car, until it finally stays on, indicating its time for an oil change (thats if it was properly reset at your last oil change).
If it's was your check engine light, then you proceed to the nearest autozone/advance/oreilley and have them check for a code. If it came on, it will store it, no matter if the CEL is still on or not.
good luck.
Old Apr 3, 2007 | 04:37 AM
onfire01's Avatar
Banned
Do you honestly think someone on the internet can diagnose the issue with these details?
its probably the maintence light anyway
wishiwasaSian2k
Nov 20, 2009 06:53 AM
badboy00z
Jun 15, 2009 10:45 AM
Fr3AkAzOiD
Aug 1, 2006 04:56 PM
Whitelightning
Dec 3, 2005 05:36 PM
