check engine light because of spoon thermo???
Old Mar 15, 2003 | 11:53 AM
BlueS2000Boy's Avatar
Default check engine light because of spoon thermo???
my check engine light has been on now for a while i kept checking the gas cap because that has happened before to me. so at my work we checked it with an obd comp and it came up as coolent thermostat? i have a spoon thermostat and fan switch, and i know that normaly wouldn't throw a check engine light so i am guessing i have a bad one. can any one comment?
Old Mar 15, 2003 | 08:36 PM
Utah S2K's Avatar
What DTC Code was set??
Could be the cap, fan connection, or failure to bleed the system properly after installing the thermostat.
Utah
Old Mar 16, 2003 | 04:35 AM
it said cooling then looked up the codes and said coolent thermostat.
Old Mar 16, 2003 | 05:31 AM
S2K_LA's Avatar
I have had my Spoon thermo and switch for over 20,000 miles. Never a CE light.
You might want to check and make sure that one of the coolant lines from the install hasn't come lose. Also check the seal arounf the themrostat housing for leaks.
Old Mar 16, 2003 | 07:14 AM
SuzukaS2K's Avatar
I think is because your thermostate open too soon and the ECU see that it's not the normal operation temperture. We had a S2000 came in to our shop with the same problem.
Old Mar 16, 2003 | 03:20 PM
can anyone tell me the correct way to bleed the system maybe i did that wrong?
.MM
Nov 11, 2009 11:08 PM
BlueS2000Boy
Feb 17, 2003 10:34 AM
Visco
Nov 27, 2002 11:23 AM
SLD2000
Oct 30, 2002 08:01 PM
jefftse
Jun 9, 2002 11:53 AM
