Check Engine Light Code #1457
Old Apr 6, 2005 | 09:56 PM
SpoonTypeR's Avatar
Default Check Engine Light Code #1457
anybody have this code before?
taking to dealer tomorrow
just wanan know anybody ever experience this code b4?and how do u fix it?thanks
Old Apr 6, 2005 | 10:05 PM
S2Fire's Avatar
Banned
Take it to AJR if the dealer doesn't help you with it
Old Apr 6, 2005 | 10:25 PM
SpoonTypeR's Avatar
yap.
thats what ben told me
Old Apr 7, 2005 | 07:31 AM
SpoonS's Avatar
THAT should be a evap code which usually is a loose gas cap i would just reset the light if it comes back on go ahead and take action !!!!!!but that should be it
Old Apr 8, 2005 | 11:02 PM
SpoonTypeR's Avatar
got it back from dealer
it's EVAP Bypass Solenoid damanged
duno what that is
but they dun have it in stock .so have to wait
Old Apr 9, 2005 | 06:03 AM
Slows2k's Avatar
P1457 will not set with a loose or missing gas cap. A P1456 will.
Old Apr 9, 2005 | 04:46 PM
hoomza444's Avatar
i got this exact code recently, and yes it's the evap bypass solenoid. my car threw it once right aroudn when my clutch lost its last leg. I did the clutch job at the same time that i ran the code, and since the clutch job meant unhooking the battery and resetting the ecu, i decided to wait to see if it threw the code again once i started the car back up after the clutch job. It hasn't thrown the code since, so i'm hoping it should be okay. I'm assuming that the evap solenoid had something to do with emissions, and i'm figuring that when my clutch disc fell apart (literally one side came detatched), the powder from the material must have gotten sent through the system?
How much was the solenoid btw? I might just replace it to be safe...
Old Apr 9, 2005 | 05:16 PM
SpoonTypeR's Avatar
it cost around $200 CDN installed here
so about $170 USD or something like that
Old Apr 9, 2005 | 06:46 PM
Slows2k's Avatar
The bypass solenoid can cause the DTC, but it is not the only possible cause. The evaporative emmisions system is very complex, and difficult to troubleshoot. I wouldn't count on a bypass solenoid fixing every P1457.
The clutch is not attached in any way to the evaporative emmisions system.
steelers743
Oct 12, 2010 08:39 AM
topcat7111
Sep 24, 2009 04:39 PM
johnquester2000
19
Nov 1, 2008 01:35 AM
dmw16
Aug 4, 2006 05:05 PM
JPNSPEC
Feb 2, 2006 07:19 AM
