Checking a relay
Any advice on checking a relay? I think you can take a Fluke meter and check the continuity??
Basically I have CEL0411. Couldn't find the problem. Went to Honda and got it diagnosed and was the Air Pump itself and relay. Ok so I bought the parts off of a guy that went FI. When changing the parts I might (yes I am a dumbass) put the bad relay back in. I went to pull up the manual online to make sure I wired it back up correctly before installing and probably picked up the wrong relay because they were sitting beside each other
Anyway to test the extra one I have without pulling the bumper off again?
Put the meter on ohms and pull a measurement across the coil pins. it should be between 2 - 30 ohms. the contacts will either be normally open, or normally closed. You may have to apply 12v across the coil to cycle it while checking the contacts for continuity. That being said, 95% of the time if the relay clicks, with 12v across the coil, it's good.
S~Factor
35
Jun 13, 2012 11:08 AM
reecespieces
Jul 6, 2002 10:07 AM
