Click at low rpm help please
Old Sep 8, 2008 | 08:36 PM
Blue_AP2's Avatar
Default Click at low rpm help please
Hey my car makes a clicking sound sometimes. So far its only 1 click. Normally when driving off in first gear or when i release the gas. I checked the axle nut. Torqued it at 220lb but it didn't move then i went to 230 nothing sill then 250 and it still didn't move. it seems as if its been torqued pretty hard since it didn't move at all. What else could be my problem for it causing the clicking noise. please help if you can Thanks
Old Sep 8, 2008 | 11:04 PM
21337R's Avatar
Stupid question: Did you remove the cotter pin before trying to re-torque them? I have read that the axle splines can click when they get dry. I would say the next step for you is to actually remove the axle nuts, re-grease the splines and install new axle nuts.
Old Sep 9, 2008 | 10:54 AM
jyeung528's Avatar
try the other side...?
Old Sep 9, 2008 | 10:55 AM
jyeung528's Avatar
also, the torque wrench can be broken...
Old Sep 11, 2008 | 10:13 PM
Blue_AP2's Avatar
where is the cotter pin? i didn't remove that. what should i grease the splines with? any high temp grease?
Old Sep 11, 2008 | 10:14 PM
Blue_AP2's Avatar
i tried both sides. i don't think the torque wrench is broken its a craftsman and its pretty new still.
Old Sep 11, 2008 | 10:43 PM
Blue_AP2's Avatar
i am going to take off the nut tomorrow and try again and grease it. also my car is an 06 is that a common problem for all s2000?
Old Sep 11, 2008 | 11:34 PM
jyeung528's Avatar
pretty common.
friend had it...thought he fixed it, but turned out the torque wrench was broken...
he was barely torquing to about 80 lbs...
Old Sep 12, 2008 | 08:47 AM
Nickamsweet's Avatar
80lbs? jees that's scary!
MrWant
Feb 19, 2012 09:23 AM
Bandit_287
Mar 20, 2011 09:07 AM
h2k
Oct 2, 2009 09:09 AM
MannyS2K
Jul 18, 2008 06:22 PM
sleekblackroadster
Jul 21, 2005 04:47 PM
