Clicking / Creaking Sound
Old Feb 18, 2009 | 05:21 PM
Honda Life Dunk's Avatar
Default Clicking / Creaking Sound
I've had this clicking or creaking sound coming from around the left rear wheel of my car ever since I bought it 6 months ago. Used the search feature and read about the common problems with CV joints and wheel splines but mine is only an occasional sound so I don't think it's either of those.
The sound usually only occurs once or twice when I'm accelerating after a gear change, or from a hill start, and mostly in 1st or 2nd gear. This made me think it might be related to something loose moving when the weight of the car is being thrown back and forth as i lift the clutch. Could also be related to a change of inertia through the drivetrain?
It is a very clear sounding creak or click and is best heard from outside the car, coming from near the rear left wheel. The sound isn't at all muffled so I doubt it is coming from inside the Diff.
Any ideas what it could be?
Old Feb 18, 2009 | 07:40 PM
negcamber's Avatar
What year car and how many miles?
May just need the axle nut re-torqued.
Old Feb 18, 2009 | 07:43 PM
jyeung528's Avatar
maybe its the wheel bearings
Old Feb 19, 2009 | 12:40 AM
It's a 2000, 100k miles.
If the problem was the wheel bearings wouldnt the noise occur constantly, not just with jerky clutch engagement at low speeds?
Old Feb 19, 2009 | 12:57 AM
istdercollen's Avatar
I'd say torque your axle nuts as it's free and if the problem is solved then good.. if not move to the next thing. Start small and work your way up.. Torque to revised specs and get back to us. BTW I have to do mine every few months.
Old Feb 19, 2009 | 05:30 AM
Almostlude's Avatar
If I was a betting man, I'd definately bet it's a wheel bearing. Had a friend of mine that had the exact problem. Change the bearing and you'll be good to go.
Old Feb 19, 2009 | 06:28 AM
negcamber's Avatar
Not necessarily...bearings will start clicking occasionally and then progress to clicking most of the time, and then squealing.
Old Feb 19, 2009 | 07:36 AM
my2ks2k's Avatar
the process is gradual. if you haven't ever re-torqued the axle nuts, do that (to about 224 lb. ft.)
if that clears up the noise, then it's more than likely the wheel bearing and you've bought yourself some time. when you start to hear the noise again, get your new bearing ordered and on the way, and go ahead and plan to change it in the near future
Old Feb 19, 2009 | 03:47 PM
Thanks all.
I'll report back when I've tried what you suggested!
Feuerrader
Sep 24, 2012 12:43 PM
bkowa092
May 27, 2011 11:51 AM
Siggy
Apr 18, 2010 09:15 PM
161MPHTOPSPDS2K
Dec 2, 2006 04:40 AM
Quivers
Dec 29, 2005 05:58 PM
