Clicking noise coming from rear of car
So Ive been having a problem lately that I've putting off for awhile.
Basically sometimes when I start from a stop, and always when I start moving forwards after backing up (like backing out of a parking spot) maybe a second or so after the car starts moving forwards there will be this relatively loud *CLICK* noise. It was really quiet before and it's getting louder now so I decided to investigate it. I thought it might just be the drive shaft clunking since it has some play in it, but sometimes it will happen after I've already started moving for a second or two, so the driveshaft should be locked under load correct?
I've been having the same problem...retightened the axle nut and its still there! Now I'm thinking it might have to do with the diff...the noise I hear is more of a popping noise instead of clicks...anyone have any other ideas??
It's most definitely the axle nuts. Check out the DIY and follow it exactly. I had this same problem a few months ago and the tightening cure it instantly.
https://www.s2ki.com/s2000/topic/929...e-nut-tsb-diy/
