Clicking in the Rear...CV Joint?
Hi all,
I started hearing this clicking in the rear of the car after I put on my 17" TE-37s. It seems to be getting worse now. When I first get on the gas in first gear and start to accelerate from a stop, I hear a clicking in the rear. If I let off the gas fairly quick (around 3000 rpms) I rear another click. After reading some posts, it seems like the symptoms for a bad CB joint. I am having trouble finding rat's post about his CB joint which contained pictures...if anyone has that bookmarked please help me. Let me know what you guys think...does it sound like a bad CB joint? What else should I test to confirm it is a bad CB Joint? Has anyone successfully created aftermarket CB Joints for our car yet? Thanks in advance!
the tsb is on the spindle nuts. they put new ones on with grease and re-torque. this only happens when shifting from R to 1 when stopped. if you are having a click when driving more then likely the inner cv joint has pitted and will need to be replaced.
save yourself $ and go to helminc.com and buy the service manual and go to hondaautomotiveparts.com and buy the cv axle from them.
so if when u go from R to 1 and it clicks a few times.
the fix is just a new axle nut torqued down to ???ft/lbs?
i'd do a search but the search seems to be broken, it gives me no results found even if i search for something as common as VOLKS
