Clicking sounds
I traded my '01 S2000 for an '02, which I've had about a month now. Almost from day one I have had this intermittent clicking sound while driving. It sounds to me like a relay or loose connection under the dash, but the dealer says it is originating where the roof meets the windshield frame. None of us can identify it precisely, and the dealer says there's really nothing that can be done. I know it's not normal - my '01 certainly didn't have it. I'm sure it's not life-threatening, but it sure is annoying. Anyone have any ideas about what this might be?
Thanks.
Jay
Thanks.
Jay
I have it too. It's from part of the roof latches that's a sub-assembly piece. When the latches are open, the springs are under different tension, so the part is held fast. With the latches closed, there's some play there. under different road conditions (bumps, undulations, ripples, etc), the latches will rattle a bit. I've learned to ignore it, as there's really nothing that can be done.
Actually, I suppose you could fit a bit of foam rubber under there, and get it to stop, but I'm afraid of what that would do to the latch long-term.
Originally posted by DrJ
Thanks for the reply. I squirted some silicone lube on the hinge, but that didn't help. I'm sure I can learn to ignore it, but, you know, you want everything "right."
Jay
Jay
Check out this link. May be in interior light.
https://www.s2ki.com/forums/showthread.php?...=interior+light
dgl1
dgl1
