clicks from rear end
Old Sep 22, 2009 | 02:33 PM
bobrad52's Avatar
Default clicks from rear end
I'm getting clicking coming from right rear wheel area. It clicks 1-4 times as I start off with the steering wheel pointed right - then goes away. It does not do it, when the wheel is pointed left. And, only occasionally when I'm starting off in a straight line. I've heard it may be axle nut torque??? It isn't spring spacers, I checked...
Any ideas?
Thanks!
P.S. where are the axle nuts exactly?
Old Sep 22, 2009 | 02:43 PM
Fast Jack's Avatar
Axle nutsne in the center of each rotor,36 mm 220ft lbs torque.Regrease replace with new nut,u can get at the dealership or order on line majestic honda.Always try the search function before posting.The pro's arn here get tired of answering the same question after about 7-8-9-10 years and get annoyed.Understandable
Old Sep 22, 2009 | 02:45 PM
tangerine151's Avatar
awesome, I didn't even have to search to get my answer. thanks for posting fastjack..
Old Sep 22, 2009 | 05:15 PM
Fast Jack's Avatar
NP
Old Sep 22, 2009 | 08:40 PM
jeffbrig's Avatar
The typical axle nut issue is exactly one pop when changing directions (fwd/rev). 1-4 pops, and only when turning right sounds more like something in the rear drivetrain. Diff/torsen or a cv joint that's going.
Doesn't hurt to try retorqueing the axle nut as a first step, though...
Old Sep 23, 2009 | 01:50 PM
Crisgo's Avatar
Does it always click 1-4 times or only 1 sometimes? Does it do it at every stop? Does it always do it when making a right? A new axle nut is a good place to start and grease the surface of the nut wear it contacts the hub. Also making sure all mounts are good as well. Good luck!
gbaker
Jun 27, 2012 04:07 PM
vufgew
Feb 4, 2012 08:20 PM
dhfreak
Jan 18, 2012 12:37 PM
unclefester
Mar 15, 2011 11:47 PM
tjbubb
Dec 26, 2007 10:07 PM
