close
Old Oct 18, 2010 | 09:44 AM
sicknastyap1's Avatar
Default close
close
Old Oct 18, 2010 | 06:35 PM
Originally Posted by 2ndTimeAround,Oct 18 2010, 06:17 PM
Notchy is normal, just means you need to change the fluid. Use Honda MTF or Red Line MTL. 2qt should be a sufficient. Transmission capacity rated at 1.56qt IIRC.
THnks man!
Old Oct 18, 2010 | 07:27 PM
wadzii's Avatar
Banned
try some torco RTF, its a full synthetic, it has put up with about 18k miles of MY abuse and the tranny still shifts good with 112k miles on it.
It's got a more aggressive friction modifier in from what i understand. They say it works better than others in trannys that see high rpm shifts on regular basis.
Old Oct 18, 2010 | 09:08 PM
yea i beat mine kinda hard but i have always heard OEM trans fluid was the best but i guess ill try something else
Old Oct 18, 2010 | 09:09 PM
I also have oem clutch and its about time for a new one, could that have any thing to do with it?
Old Oct 19, 2010 | 06:53 AM
wadzii's Avatar
Banned
unless its warped or the springs are 1/2 way out I dont see it causing shifting problems.
Old Oct 19, 2010 | 07:37 AM
Kermdaddy's Avatar
I use GM Synchromesh Friction Modified in my tranny. I like it a lot.
Old Oct 19, 2010 | 08:28 AM
chuhsi's Avatar
oem fluid. i've tried gm and amsoil. oem worked best for me.
be sure to change clutch fluid if you're getting notchiness.
Old Oct 19, 2010 | 09:29 AM
great info guys thanks a hole lot!
Old Oct 19, 2010 | 10:22 AM
dammitjim's Avatar
Tons of info on this in the Under the Hood FAQs
