close
Old Oct 19, 2010 | 11:54 AM
sicknastyap1's Avatar
whats guys
I have a 05 bb with 65k on the tran is starting to get notchy is this normal? I have changed the fluid twice using oem honda!! Is there something better?
plus i think its about time for a new clutch!! any info would be great thanks
Old Oct 19, 2010 | 12:43 PM
03_BB_S2K's Avatar
well with the cooler temperatures it's ok to be notchy for the first little while of driving the car. It shouldnt be notchy after driving until the transmission warms up
Old Oct 19, 2010 | 12:50 PM
slipstream444's Avatar
You can try other fluids - every transmission is a little different (it's made by Aisin - not Honda). My transmission ('04 AP2 trans) seems to work best with Amsoil MTF - which is a full synthetic - and is a direct replacement fluid for Honda MTF.
As 03_BB_S2K stated - the colder temps are causing your issue more than anything else. The solution for transmissions with that characteristic is to double-clutch the first several shifts from 1-2 and 2-3. You'll get used to it and it'll become second nature very quickly. The colder it gets - the more you'll need to do this. Once the transmission is up to temp - it'll be smooth.
Old Oct 19, 2010 | 01:35 PM
yes that is true when the car is warmed up it does fill a lot smother
Old Oct 19, 2010 | 01:36 PM
i am running a oem clutch right now think about going with the act streetclutch kit and a light weight fly wheel
Old Oct 19, 2010 | 06:15 PM
H22toF20's Avatar
Wrong section and this has been covered ALOT.
I'm running Royal Purple MTF. Over 4k miles and going strong.
Old Oct 19, 2010 | 06:32 PM
Supra-holic's Avatar
Yup same here, with Honda MTF under 15K miles. For me, temperature is the greatest variable on shift quality. If I do a nice run through the gears and stop at a light or something and it heat soaks for 3-4 mins. It shifts like butter afterwards. THATS WITH 147K ON AN 06, still on the stock clutch.
Old Oct 19, 2010 | 07:16 PM
i have herd bad thing about royal purple
Old Oct 19, 2010 | 09:14 PM
H22toF20's Avatar
Don't believe everything you hear. One of the biggest things I've learned over the past 4 years of browsing forums, is ALWAYS have your "BS filter" on.
I ran Royal Purple in my H22 for over 30k miles with zero issue's(changed every 3k miles). Now I run it in my MY00(motor, tranny, diff). The motor oil has over 4k miles, it looks great and the motor is strong.
I'd like to try Amsoil but no one sells it locally. Off the shelf, Royal Purple is the best I can get my hands on.
Old Oct 19, 2010 | 10:20 PM
alSpeed2k's Avatar
Lol, me too! slipstream444 seams to have had a really bad experience with RP:
https://www.s2ki.com/forums/index.php?showt...post&p=19682180
Personally, I've never used it and have nothing against it but I would probably never run it b/c there's alternatives that I rather use that are either cheaper or the same price. For my tranny I use OEM Honda!
