Cltuch problems
Does this happen every time? Or just randomly? If it happens every time i would imagine its still the clutch fork issues.
If its random then yes it could be your master. You can exchange the fluid with a syringe or turkey baster yourself and then see how it feels after a good bleed. If the problem still persists then you might want to look into a master cylinder.
As for the slave, once they go, they usually dont work at all so you would know if it was that.
Then I will post the update. Thank you.
ok. I have changed the fluid, but problem is still exist. Symptoms are still the same. The fork doesn't pop out of its hanger, because its new. But as soon as I start going higher rpms clutch pedal would act really weird. What else could be a problem. I have never had that problem before the clutch change.
