Cluster out, top won't go down
Old May 25, 2009 | 11:56 AM
DCIdevil's Avatar
Default Cluster out, top won't go down
My gauge cluster went out the other day, it's flickering ever so faintly though.
I dont have a RPM, speed, fuel, temp... nothing.
My top won't go down either.
I was doing some reading and i think it's related to the Vehicle Speed Sensor (VSS), has anybody else had this issue?
any help is greatly appreciated
thanks
Old May 25, 2009 | 02:31 PM
DCIdevil's Avatar
update:
With the key in the on position and if you turn the lights on you hear a bunch of rapid clicking sounds coming from behind the cluster. Only when the lights are on though and the key is in the acc on position (doesn't do it in the run position). The lights do work though all of them
EXCEPT the rear side led running lights and the front running lights are flickering all dim like at the pace the dash is flickering, only when the lights are off though.
Old May 25, 2009 | 04:40 PM
DFWs2k's Avatar
alternator?
Old May 25, 2009 | 05:41 PM
DCIdevil's Avatar
It fires up everytime with no issues though
Old May 25, 2009 | 07:54 PM
DFWs2k's Avatar
it starts up off the battery/starter, not the alternator
Old May 26, 2009 | 08:36 PM
DCIdevil's Avatar
My power steering completely went out today.
I ordered a VSS today and it will be here thursday so hopefully that's it.
Old May 26, 2009 | 08:43 PM
Nickamsweet's Avatar
Could try doing the mod to remove the VSS cable so that the top can be put up...
Old May 27, 2009 | 04:08 PM
DCIdevil's Avatar
I guess it could determine that if the vss is faulting if i did the mod and the top would then work.. hmmmm...
(the top is currently up btw no worries there).
Old May 27, 2009 | 05:48 PM
oh ok I thought that the roof was down lol... least it's up and secure... try the VSS thing or no change?
Old May 27, 2009 | 06:35 PM
DCIdevil's Avatar
i cut the vss wire and the top now goes down. gauges are still really messed up. getting a new vss tomorrow
oh and thanks for the help dude
