Clutch
Old Apr 2, 2012 | 09:49 AM
deanbayley's Avatar
Default Clutch
Hi all. Just been out in the beast. 12000 miles on the clock and I got clutch slip real bad. I was on a quite steep bit of road and wanted to get the tail out when pulling off round the corner, but the clutch just slipped. It stunk! Is this normal?
Old Apr 3, 2012 | 02:56 PM
s2klariat's Avatar
The slip or the smell? A "burnt" clutch smells terrible. The slip can be caused by a few things. Worn out clutch disk, low clutch fluid, faulty slave cylinder, driver error, the list goes on.
Old Apr 3, 2012 | 04:30 PM
slalom44's Avatar
Top Answer: 1
I disagree. Low clutch fluid won't cause clutch slipping. A faulty slave cylinder causing those symptoms is highly unlikely. You probably have a worn cluth. There are other possibilities but if your clutch pedal feels normal, you're going to have to drop the tranny and see what you have. Burning your clutch wears it out extremely fast.
A worn clutch in 12,000 miles is poor but it isn't a record. I've seen a few others claim less miles on their clutches.....
Old Apr 3, 2012 | 05:51 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you can feel freeplay in the clutch pedal (and you should) your clutch is toast. An over adjusted clutch master cylinder pushrod can cause slip, but I'm pretty confident you wont find that.
Correct ^ ...clutch fluid has nothing to do with the clutch's abilty to grab.
It has everything to do with a clutch's ability to disengage, to allow proper shifting.
Old Apr 3, 2012 | 10:28 PM
deanbayley's Avatar
Normal driving the clutch feels fine, like new. I have tried to put it under load again but it doesn't slip. I'm going to get it checked out still. Annoying. Don't suppose it's a warrantee item? I have 3 years left
Old Apr 3, 2012 | 10:46 PM
ahrmike's Avatar
Are you driving an AP2? Perhaps its the maligned delay valve
Old Apr 4, 2012 | 04:29 AM
deanbayley's Avatar
Yes. My06. It also seems to bog or stutter at low revs. Could that be te same issue?
Old Apr 4, 2012 | 09:54 AM
calebzimm's Avatar
Originally Posted by s2klariat
low clutch fluid
I'm not even remotely surprised that a dealership would misinform me, but I went and had my trans flushed the other day and asked that they also replace "any fluids associated with the clutch." I was quickly informed I was wrong and that it was a totally dry clutch. While the clutch itself may be dry there is still hydraulic fluid that operates the slave cylinder, correct? I'm assuming that's what you are referring to and if so, what's the "proper" way to go about replacing this as the dealership obviously has no clue.
StrokerSi
Aug 10, 2017 06:26 AM
armthehomeless
Mar 31, 2012 02:47 PM
Gh0ztt
Feb 18, 2008 06:43 PM
Big_Al
Nov 11, 2005 11:45 AM
