clutch buzz after new clutch
Old 05-19-2009, 08:11 PM
bbak11010's Avatar
Default clutch buzz after new clutch
hey all,
I have recently replaced my clutch, pp, and flywheel with the ACT package..
My clutch was going bad... but I was really getting annoyed by the clutch buzz.
So I got all those installed... and clutch buzz is still there.. Is this supposed to be normal? or do you think the noise is coming from somewhere else?
If this is normal,.. I was thinking of Dynamatting the floor to reduce the noise.. has anyone done this who can tell if this helps or not?
Any comment or help is appreciated!
Thanks,
Old 05-19-2009, 11:33 PM
tronvex's Avatar
The S2000 does lack of installation to reduce outside noise and it doesn't help when the transmission is mounted center of the cockpit. I don't like the clutch buzz either but I just learn to live with it.
Old 05-19-2009, 11:53 PM
bbak11010's Avatar
thanks for your input.
i read about people having no issues with clutch buzz after they go with an aftermarket clutch kit.
is this for certain clutch kits only?
Old 05-20-2009, 06:15 AM
negcamber's Avatar
I would bet your noise is from another source.
Old 05-20-2009, 06:28 AM
bbak11010's Avatar
what could cause a noise similar to clutch buzz?
Old 05-20-2009, 06:08 PM
negcamber's Avatar
Loose heat shield...different tranny issue (input shaft bearing)...
Old 05-20-2009, 06:12 PM
Slows2k's Avatar
Was a ACT disc or OE disc installed? Which ACT pressure plate was used? The ACT street disc and pressure plate has always had a reputation for quiet operation under decel.
Old 05-20-2009, 08:15 PM
bbak11010's Avatar
thats what i thought. it was the ACT street clutch kit, with HD pressure plate.
hmm.. so.. its something else???? if i take it to a shop, would they be able to find out the problem without taking the tranny off?
Old 05-25-2009, 12:51 PM
bbak11010's Avatar
anyone??
Old 05-25-2009, 05:19 PM
Slows2k's Avatar
ACT street clutch disc are normally quiet. You sure you didn't get a different disc?
richardaguilar95
09-12-2017 01:16 PM
S2Kaz06
03-20-2012 11:56 PM
21k
08-16-2009 02:37 PM
B.Money
04-18-2007 10:38 AM
axiom
08-21-2002 06:48 AM
Quick Reply: clutch buzz after new clutch
