Is this clutch buzz or transmission buzz?
Old Feb 2, 2009 | 11:25 AM
s3ngk4ng's Avatar
Default Is this clutch buzz or transmission buzz?
I notice the buzz when I decelerate in 4th gear and not any other gear. And as expected of a clutch buzz, when the clutch is pressed, the noise goes away. Is it clutch buzz when the noise occurs only in 4th gear? I don't get any buzz in any other gears.
Also, sometimes [not every time], when I am accelerating fast in 4th gear and stomp on the clutch and put the gear into neutral and start decelerating in neutral, i hear the same noise... and pressing the clutch or releasing the clutch doesn't do anything to get rid of that same buzz while i'm slowing down in neutral.
And just 2 hours ago, i heard the same buzz while accelerating in 5th gear for the first time ever
Is this clutch buzz or transmission buzz or something else i'm unaware of? And if it is transmission buzz, is it covered under warranty for MY06?
Old Feb 2, 2009 | 11:37 AM
Tjs S2k's Avatar
Mine does the same thing!!!! Someone answer! Mine buzzes on accel too... but only after I got a new clutch. Also, if I am going slow in first gear and push in the clutch to put the car into nutruel, it clanks really really bad ...
Old Feb 3, 2009 | 04:25 AM
asukadc's Avatar
i'm not exactly sure , but i hear people talking about timing chain tensioner ?
Old Feb 5, 2009 | 08:49 AM
s3ngk4ng's Avatar
Can the claim about timing chain tensioner be verified? I probably doubt this, but this isn't covered for AP2 2006 models right? There's only 1 tsb for the 06, and it's not related
Old Feb 5, 2009 | 09:15 AM
2poor2mod's Avatar
i highly doubt that it is the TCT based on the symptoms given
Old Feb 6, 2009 | 06:32 PM
s3ngk4ng's Avatar
Yeah, I don't think it's related to engine, but rather the transmission or differential.
Anyone have a similar situation?
Old Feb 8, 2009 | 04:03 PM
romaniac85's Avatar
Hey people,
ALL AP1'S have this problem. It's a manufacturing fault that's been covered by Honda's notice board thingy. It comes from the Flywheel and it's nothing to worry about. I have the same noise, many other people have this noise and you'll also notice you'll get it louder when the air-con is on.
Good news is that if your car is under warranty, you can claim it and get a new flywheel/clutch. My AP1 has 130,000km (80,000miles) and nothings gone wrong (except my roof and radiator).
Hope this helps.
Ps. Outside the car, it sounds sick whent he noise is on!!!
Old Feb 8, 2009 | 08:39 PM
s3ngk4ng's Avatar
Thanks romaniac85 for the flywheel info. Unfortunately my car is an AP2 06 model, so there's almost no TSB's covering it. I don't think this is covered under warranty? I don't want them to diagnose it just to say sorry it is not covered by warranty
smad
Mar 17, 2013 12:45 PM
omg_miiiike
May 10, 2010 02:55 PM
IIGQ4U
Mar 12, 2010 10:15 AM
dyhppy
Nov 8, 2006 05:35 PM
lukemc01
Jan 1, 2005 07:28 AM
