Clutch Fluid Change
I did this a little over a week ago on my recently purchased '00 s2k. Since I wasn't sure if it had ever been done, I did it again last night, and sure enough there was a little gunk (nothing like the first time). So, if it hasn't ever been changed (or not changed in a long time), you may want to do it a couple times.
Up until now I've just bled the clutch. The last time I had to have my wife help, which is like pulling teeth. It's nice to see an alternate method that works. I've done the clutch bleed enough times that my reservoire reamins pretty clean, but the fluid turns a darker amber after a couple of years.
Does emptying the brake reservoire and refilling a few times accomplish the same thing. Or do you still have to bleed the brake valves?
Thanks Billman!
Thanks Billman!
Thanks Billman!
Thanks Billman!
I also use my wife to help me bleed my brakes after I work on them, she does it but very reluctantly, lol.
Again, I'm not sure how much of that you will flush out by just bleeding.
Suppose your pads are 2/3 worn, there will be a certain volume of fluid in the calipers to compensate.
That fluid will heat up, get old, absorb moisture, ect, ect and may give a spongy brake feeling.
There is only 1 way to get it out for sure: push the piston all the way back in with the bleeder open - so you don't push the old fluid back into the lines and maybe as fas as into the ABS pump
It will fill up with fresh fluid from the reservoir first time you press the brake - and second, and third
Just did this yesterday. Filthy fluid in there! I used a drinking straw to suck out the fluid. Just suck up a bit before it reaches your mouth of course. I filled it with new fluid, stirred it up and sucked it out again.
