Clutch fork buzzing?
Old Jun 30, 2011 | 06:58 AM
RichwiththeS2000's Avatar
Default Clutch fork buzzing?
See part 4 here:
http://www.hondaoriginalparts.com/ho...block_03=19271
I saw in a youtube video this is a comon cause of the clutch buzzing. Theres some sort of rubber washer I think on each side of the metal bar which wear away giving the fork space to vibrate and hence causing the buzzing noise.
Has anyone on here ever tried replacing this part to cure a loud clutch?
Does anyone know if it can be replaced without having to remove/dismantle the gearbox?
Old Jun 30, 2011 | 07:03 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The washers on the fork are solid steel. They are not worn, and that is not the problem.
You need to pull the transmission to replace the fork. But it will not cure clutch buzz. a new oem disc will.
h4mmer
Sep 21, 2011 09:59 PM
RichwiththeS2000
Jun 30, 2011 12:26 PM
cpx3mbp
Nov 9, 2010 05:31 PM
21k
Aug 16, 2009 02:37 PM
bbak11010
May 25, 2009 05:19 PM
