Clutch Fork, or Slave cylinder? PICS! help :|
So right now I just got done doing my clutch. We had the transmission almost on and I put the fork in threw the outside and got it in there. well the transmission and back up and I attached the slave cylinder and my pedal is soft..
I look at where the fork was and it looks like it see suppose to be farther back? When i put the slave cylinder on it, I don't even need to compress it to get it in there >,<! The problem is it is at it's max so the fork must not be positioned correctly?
I can have the rod come out any further so something is screwed up here are the pics.
This is where the fork is.
If you can see the holes to bolt it on align perfectly but I didn't need to compress it to make it fit.. lame..
Again it is lined up and i didn't have to compress it. The slave cylinder is at max like taking it off and not compressing it, what did I do wrong?
Originally Posted by chris_barry,Sep 22 2010, 05:49 PM
Remove your slave and pull the fork outwards, push it back in making short the end of the fork is engaged in the slot on the thrust bearing.
It looks like you missed the slow when pushing it back in.
richardaguilar95
Sep 13, 2017 06:34 AM
