Master or slave clutch cylinder?
Old Apr 21, 2008 | 10:09 AM
Fusiondynamics's Avatar
Default Master or slave clutch cylinder?
I think one or both of those things are done for.
My clutch is really soft and there is no pedal feel until about half way down and the engagement is close to the floor.
It was like this one time and I did a clutch fluid bleed and it fixed the problem.
I bled it this time and it still feels mushy.
Should I replace the Master or slave or both?
Car has about 100k now.
Also is it normal to be able to put the car in gear without stepping on the clutch pedal?
Thanks in advance.
Old Apr 21, 2008 | 10:19 AM
sharkbite's Avatar
can u see if the master is leaking by the firewall, it sounds like to me that its the slave, my lude did the samething.
Old Apr 21, 2008 | 10:33 AM
TrackStar's Avatar
Replace the slave first asit's like $60. Also these items show wear over time so even if you need to replace the master, the car will feel better with the slave replaced as well.
richardaguilar95
Sep 13, 2017 06:34 AM
roel03
Jan 29, 2013 07:13 AM
03S2
Feb 20, 2011 02:17 PM
DDuds2k
Nov 6, 2008 07:17 AM
airsport
Nov 5, 2003 05:23 AM
