Clutch freefalls to the floor and does not return!
Old May 15, 2003 | 04:20 PM
  #21
airsport's Avatar
Service manager told me that it is a sealed bearing. No place to grease without removing it...
Old May 15, 2003 | 05:20 PM
  #22
cdelena's Avatar
That is correct, but the inside surface that is slipped over the main shaft has a groove that is supposed to carry high temp lube added when installed. I found no lube on that surface, or on the splines that the FD slides on, or on the fork. When I put mine back together properly it was smoother and quieter.
Old Jun 22, 2003 | 06:40 AM
  #23
KJDDMD's Avatar
This happened to me last night 2 days after I had the clutch plate replaced under the TSB for buzzing on deceleration!! Anyone else have this happen??
Old Nov 4, 2003 | 06:58 PM
  #24
Helios's Avatar
I'm resurrecting this thread because last Friday, I more or less experienced what airsport went through back in May.
While driving to work, I depressed the clutch pedal to shift from second to third -- and it failed to spring back. Long story short -- pried the pedal back up; drove home in second gear w/incredibly stiff clutch. Flatbedded to dealer.
Diagnosis: blown out release bearing. Bearing/clutch disc/pressure plate replaced under warranty. New clutch action is smoother than before, leading me to believe the tech applied some grease to areas not previously lubed. I just brought the car home tonight and will get more details tomorrow.
Quick facts: my car is an '02 w/14,850 miles. No high-rpm clutch drops. I never ride the clutch, try to rev-match when downshifting, and have never tracked or auto-crossed. 50/50 mix of backroads weekend drives and urban stop-and-go. I always tried to be gentle on the clutch, because I didn't want any problems, but I guess they just found me.
Old Nov 5, 2003 | 03:41 AM
  #25
airsport's Avatar
Did the service manager say it was probably your driving habits that cause the failure? Or that the warranty was over at 12,000 miles and they would do a good will warranty?
Or did they just fix it? The service department in Tallhassee just plain sucks.
Old Nov 5, 2003 | 05:23 AM
  #26
Helios's Avatar
[QUOTE] Originally posted by airsport
StrokerSi
Aug 10, 2017 06:26 AM
S_cav
Dec 23, 2011 11:20 PM
03S2
Feb 20, 2011 02:17 PM
Edberg
Jan 19, 2010 10:40 AM
heffergm
Mar 21, 2004 04:56 PM
