Clutch issues
Old May 28, 2011 | 09:07 PM
drfzrx's Avatar
Default Clutch issues
Im not sure how to describe this issue, but here goes...
on the 1-2 shift, just as i release the clutch and maintain steady gas input, the power delivery is not steady. the car surges forward haphazardly. even though the accelerator is steady, its as though somone is flipping a toggle switch with the power. I can stop the on-and-off-power delivery by pressing the clutch or adding more gas. is this a slipping clutch? I dont notice it slipping at any other gear or situation. I doesnt happen all the time but its happened a few times to me this week.
I have a 2004 with 25k miles. all stock.
Any thoughts?
TIA
Old May 28, 2011 | 10:06 PM
si2ik's Avatar
yea this happens to me also, i think its either im shifting to early or not enough gas
i just got a new clutch, so it cant be the clutch
Old May 29, 2011 | 01:23 AM
FluKy15's Avatar
All I can think of is your letting your clutch out too quickly . It doesnt do that while your in second fully right.
Old May 29, 2011 | 11:28 AM
jojipoji's Avatar
Cdv do a search on clutch delay valve
Old Aug 24, 2011 | 12:48 PM
WolfpackS2k's Avatar
^I'm pretty sure CDVs weren't installed on S2000's till the 2006 MY. He owns a 2004.
Old Aug 24, 2011 | 03:14 PM
Paradoxicalcook's Avatar
CDV's are installed on 04-05 slave cylinders unless you remove them. It is the delay valve. If you time your pedal work you can get around it for the most part. I disabled mine to get rid of Honda trying to be my parent.
Old Aug 24, 2011 | 06:09 PM
RedCelica's Avatar
let the clutch out before you get back on the gas, problem solved.
Seven11
Apr 7, 2021 10:50 AM
rbtz
Sep 4, 2017 10:08 AM
lols2000
Jun 23, 2009 04:07 PM
kartrcr4life
Jul 6, 2008 12:29 PM
youngjun91
Apr 9, 2005 11:36 PM
