clutch not disengaging?
Old Aug 12, 2008 | 08:21 AM
omgitsoop's Avatar
Default clutch not disengaging?
this problem happens maybe every other day, and never on the day a mechanic looks at it of course: sometimes, more often when its cold, i will push down the clutch pedal, then try to pull out of whatever gear, but it resists it. Its pretty much the same resistance you get when you pull out of a gear without depressing the clutch. it resists more than usual, but once i get it out of gear it opens up and i can go into the next gear just fine, its always fine going into the gear its pulling out where it fights me. sometimes this will happen once or twice in the morning, sometimes it will go on for a good hour or more. p.s. my clutch pedal itself never sticks. im at 62,000 miles, im thinking of just replacing my clutch anyways, if someone could just link me to all of what i need on hardtopguy that would be sweet.
Old Aug 12, 2008 | 12:45 PM
HankookS2K's Avatar
all you need to get is the act pressure place. hardtopguy will still use the oem disc and oem flywheel. im assuming its just your disc still sticking to the flywheel, i had the same problem on my clutch, i had 125k on the clutch the disc was sticking.
that problem should go away with the new clutch.
Old Aug 12, 2008 | 02:24 PM
omgitsoop's Avatar
Just out of curiosity, i have a bone stock car, why would i need an aftermarket pressure plate? and is that all i need? id like to replace whatever is most likely to go out next since ill already have it open
Old Aug 12, 2008 | 02:41 PM
HankookS2K's Avatar
sorry i thought you were asking for the setup that hardtopguy has. the setup that is more preferred is the oem disc and flywheel with the act pressure plate, its just a stronger setup.
if you want to replace strictly all oem and your car is bone stock, that is fine, u can still get the oem pressure plate. since you already have it open check to see if the disc needs to be replaced. with 62k on the clutch i would replace the disc. then check to see if you can resurface the flywheel. the pressure plate is up to you. u can keep the stocker or get the act for a stronger clutch.
Old Aug 14, 2008 | 06:23 AM
terrors75's Avatar
Hey guys,
I think I'm having the same problem as omgitsoop, but with a little different issue. Like when I go into second gear it feels like I'm rubbing against something and it the car feels like it doesn't really want to pick up. So, I've decided to change out the plate, clutch and disc. What would be a better purchase? Spoon or ACT or if you have anyother suggestion that would be much appreciated.
Thanks
Old Aug 14, 2008 | 07:07 AM
HankookS2K's Avatar
act pressure plate, oem disc, oem flywheel is perfect.
Old Aug 14, 2008 | 07:36 AM
terrors75's Avatar
So, I wouldn't need a new release bearing or anything else? If it's just the pressure plate, great! I can save a ton of money... =)
Old Aug 14, 2008 | 08:02 AM
terrors75's Avatar
So which ACT plate should I get that comes close to the feel of my stock clutch and can someone PM me a website i can find a pressure plate? I've looked in Modacar and they sell the whole package I think. It cost around $539.00 with ACT Clutch Organic street disc and heavy duty pressure plate.
kondata
Jul 10, 2013 10:16 PM
preludepatrick
Dec 29, 2012 11:04 AM
03GPWs2k
Jan 31, 2012 06:23 AM
skem
Sep 12, 2009 09:02 PM
IntenseImports
May 12, 2008 12:14 PM
