Clutch pedal adjustment
Just wanted to make sure I had this correct. My clutch pedal before had tons of slack in it.
So I backed off the clutch switch at the top until it didn't touch the clutch anymore. Then adjusted the rod until my pedal length was roughly 7" ( I was compensating for carpet etc.) and my travel is right about 4.7"
This sound correct? I saw everyone just adjusting the slack out of the pedal, but the manual specifies to unscrew the switch off the clutch and then adjust it. After its adjusted, turn the switch until it touches the clutch, then one additional turn.
