clutch pedal not coming back up
well i started out with a differant problem at first. originally i was having to press the clutch pedal further and further down to get the car in gear, so i thought slave cylinder. about an hour ago before i replaced my slave cylinder i noticed my clutch pedal would'nt come back up on its own. i went ahead and replaced the slave cylinder and i am still having the problem with clutch pedal not coming back up. please help i am completly lost
does this usually take awhile? i have had my wife out pumping the clutch and holding it down while i open the bleed for the little bit of pressure that has built to escape(AIR). But we have been doing that for about 15 minutes. do i just need to continue doing the same thing? oh and should i eventually feel a differance in the clutch?
ill go check behind the clutch pedal. would it really be noticable, i mean would fluid be visible? the master cylinder reservoir is still full, i dont know if that means anything. thanks for everyone, your being very helpful.
