Clutch Problem
Old Oct 12, 2008 | 05:43 PM
9kred's Avatar
Default Clutch Problem
Hey guys, last night my clutch/pedal started acting up. The car has 63k miles and dont know if the previous owner ever changed the clutch but it should be changed in the next couple of thousant miles. When i bought the car, there was a small gap on the pedal where once you press it nothing happens and then the clutch feel comes out. Last night as i drove back home from work, this gap started increasing rapidly. The gap increased to about 60-70% of nothing and than the clutch kicks in... It was a cold night for the first time in forever here in AZ so dont know if that has to do anything with the problem. Dont know wtf is going on so if anybody has any ideas or suggestions would much appreciate it!!
Old Oct 12, 2008 | 05:53 PM
s2k aok's Avatar
isn't there something in the owner's manual about adjusting the pedals? maybe it's just a simple tightening up of a bolt/nut or something...
Old Oct 12, 2008 | 09:48 PM
9kred's Avatar
Thx for the suggestion. Anybody else??
Old Oct 13, 2008 | 10:41 AM
9kred's Avatar
Anybody?
Old Oct 27, 2008 | 06:07 PM
J.Garage's Avatar
Have you checked your fluid level in the clutch master cylinder?
Maybe it needs to be bled.
I know I checked out the fluid recently and it was really dark, and had a lot of residue in the system, so I had it completely flushed and now it works a lot better.
Old Oct 27, 2008 | 06:11 PM
skeithr's Avatar
also take a flash light and look inside your car where the clutch attaches into the firewall and see if any brake/clutch fluid is starting to come through. not just grease but actual fluid, if so it might be time for a new master cylinder
Old Oct 27, 2008 | 10:39 PM
9kred's Avatar
Thx for the replies people, but i solved the problem by bleeding the clutch. There was a LOT of air in the lines and the oil was wayyy black and dirty, but changed the oil out and it is
rickw06
Jan 2, 2014 10:52 PM
Croc
Apr 6, 2011 10:10 AM
Pointblank
16
May 22, 2007 10:25 PM
sanee515
Aug 23, 2004 01:51 PM
piecesofcurb
Aug 26, 2003 04:13 PM
