Clutch question
Old Jun 29, 2015 | 06:41 PM
westernflyer's Avatar
Default Clutch question
Hello S2K owners,
I have a 2005 that has 141K on it. It has driven beautifully until this morning when I started it up. I noticed that the clutch did not have its usual smooth engagement, but rather felt like the "air had been let out" of the clutch pedal until it got down to the very bottom. It then felt like it engaged, but only over a very small range, again with the rest of the engagement range feeling "empty." It is now being difficult going into reverse also. What might be the most likely problem? Am I low on a fluid that needs to be topped off, or it is a more problematic fix? sure owners have seen this before, and I could sure use some help with it.
Thanks!
Old Jun 29, 2015 | 06:45 PM
B serious's Avatar
....well....are you? I can't see it from here. Something is blocking my view.
Old Jun 29, 2015 | 06:49 PM
B serious's Avatar
Step 1 is to look at the fluid level.
If its low...you have a leak somewhere. Relatively easy fix.
If its not low...you might have broken a clutch spring or have another failed internal component. Is the clutch OEM Honda?
Or there may be an internally leaking slave or master cylinder. Meaning a seal is bad, but its not leaking fluid externally.
Old Jun 29, 2015 | 07:29 PM
Forgive my ignorance on this subject, but where is the fluid reservoir and what kind of fluid does it take?
Old Jun 29, 2015 | 08:35 PM
Soviet's Avatar
To the right of the brake fluid reservoir in the top right corner of the engine bay. I believe it takes DOT 3/4 brake fluid, nothing special.
Old Jun 29, 2015 | 09:13 PM
cosmomiller's Avatar
Top Answer: 1
Be sure to wipe up any spills with lots of water/cleaner. Brake fluid is very harsh on rubber and paint.
Old Jun 29, 2015 | 09:45 PM
windhund116's Avatar
Brake fluid is very bad for paint. But, ok for most rubber parts. Ppl actually used to treat rubber things (like tires) with brake fluid, before the days of Armor All.
Old Jun 30, 2015 | 02:30 AM
B serious's Avatar
Lol. That doesn't seem like it'd splatter all over the car's fenders at all. :/
Pricey1959
Mar 22, 2015 03:47 AM
s2kking
Jan 16, 2014 09:32 AM
ebchu
Oct 17, 2009 08:59 AM
epaplia
Oct 20, 2008 10:16 AM
msmokie
Oct 25, 2007 06:05 PM
