Clutch recommendations!
Old Jan 24, 2011 | 02:23 AM
  #21
etang789's Avatar
SOS all the way!
Old Jan 24, 2011 | 05:04 AM
  #22
LattiS2000's Avatar
clutch burnt, just bought this one, cheapest fix, if u buy just an exedy clutch u need to cut down the fly wheel so i recomend u get a fly wheel as long as the clutch.
http://cgi.ebay.com/ebaymotors/EXEDY-OEM-C...sQ5fAccessories
Old Jan 24, 2011 | 05:49 AM
  #23
PanteraKitty's Avatar
I burned through an OEM clutch in 25,000 miles so I upgraded to an ACT clutch.
http://www.clutchcityonline.com/
Old Jan 24, 2011 | 03:38 PM
  #24
vooper's Avatar
AP1 flywheel
ACT HD pressure plate
OEM clutch disc
AP1 clutch cylinder or remove the CDV from the AP2 cylinder
Should hold up to 350torque.
Old Jan 24, 2011 | 03:55 PM
  #25
BanzaiS2K2003's Avatar
Exedy oem
Old Jan 24, 2011 | 05:53 PM
  #26
305AP1's Avatar
I have the ACT street clutch and pressure plate and I couldnt be happier its has a very aggressive bite but it is very daily drivable
Old Jan 24, 2011 | 07:36 PM
  #27
EstooK's Avatar
@vooper I like what you stated about your set up, That is something I am interested in having. Is your set up for NA or forced induction? And anyone have a SS clutch line? How does it improve engagement?
Old Jan 24, 2011 | 08:26 PM
  #28
vooper's Avatar
Estook, you're astute in noting that it is more of a multi-part setup rather than a single component change. The one I mentioned will easily hold a small turbo or most superchargers. I'm running NA.
Old Jan 25, 2011 | 12:39 AM
  #29
R00567's Avatar
Originally Posted by vooper,Jan 24 2011, 04:38 PM
AP1 flywheel
OEM clutch disc
has this been tested or is it a guesstimate bro?
Old Jan 25, 2011 | 07:34 AM
  #30
vooper's Avatar
It's tried and true. Multiple threads document various members' experiences on this combo (including some who make a living working on S2000s). The concept of the change starts with AP2s that have the CDV. However, slight clutch slip was still noticed when the CDV was removed. This was attributed to the heavier flywheel on the AP2s. Many have changed to an AP1 flywheel (14lbs vs the 22lbs AP2 flywheel) or an even lighter aftermarket flywheel. This helps match up the flywheel to the CDV. This leaves the pressure plate. Upgrading slightly to something like an ACT HD adds only minimal stiffness to the clutch pedal and increases the capacity to hold more torque (by about an additional 40% -- as per the ACT website). This leaves the disc. I like the OEM feel, lack of noise, and the engagement. I don't see any point in changing the disc unless someone is unhappy with these characteristics.
