Clutch replacement
Old Jun 6, 2005 | 01:35 PM
007 S2K's Avatar
Default Clutch replacement
Ok, to do a clutch replacement on an S2000 with the stock cluch is this all i need from the store
The Friction Disc
The Pressure Plate
The Throwout Bearing
http://marketplace.s2ki.com/s2ki/home.php?cat=13
If so that would mean that i could do a complete clutch replacement (with the labor being done by me) for: 360.00 (+-)
DAMN, they quoted me like 850 bucks at the dealer.
Old Jun 6, 2005 | 03:02 PM
Slows2k's Avatar
You'll need some high temp grease for the bearing and shifter as well.
Old Jun 6, 2005 | 07:11 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
A pilot bearing would be nice.
If the flywheel is burnt, I'd think about replacing that too.
Honda does not recommend cutting the FW, but it has been done by myself and others with no troubles. It is vital that the dowel pins be removed and the step be equally ground for height, and trueness.
Old Jun 6, 2005 | 07:40 PM
Gregg Lee's Avatar
[QUOTE=007 S2K,Jun 6 2005, 04:35 PM]Ok, to do a clutch replacement on an S2000 with the stock cluch is this all i need from the store
The Friction Disc
The Pressure Plate
prj3ctm4yh3m
Jun 26, 2011 12:59 PM
Tassill
Feb 9, 2010 08:24 PM
brian10jones
Feb 2, 2009 05:03 PM
s2kntx
Nov 3, 2006 05:56 PM
s2000honduras
Dec 11, 2005 09:39 AM
