Clutch Replacement
Old May 24, 2012 | 08:48 AM
CT_00_S2K's Avatar
Default Clutch Replacement
Hi S2K lover . I got my car a year ago its a 2000 s2k and its time for a clutch replacement at 140k.I know there's alot of forums out there about this topic but they wasnt specific on which motor mount to take off and which bolt should I take off from the mount. And how should i surport the engine ? Sorry to sound like a novice . Hopefully you guys can help me . Thank you ...
Old May 24, 2012 | 08:54 AM
japhethwar's Avatar
You don't take any engine mounts off. Just loosen the six bolts that hold the front subframe in. You only need to lower it a couple of inches. No need to support the engine. No offense but it sounds like this may be out of your league. Find a friend with some knowledge or call a pro.
Old May 24, 2012 | 09:17 AM
CT_00_S2K's Avatar
Thank you for the reply Jap .I have done a clutch before on my civic but this look like a whole different ball game . I just wanting to know about the engine tilt thats all. How can you learn if you dont do it yourself right ? I got a couple of my buddys coming over and helping me they have some knowledge.
Old May 24, 2012 | 01:43 PM
zeroptzero's Avatar
There is quite a procedure to get to the point of removing the tranny, including support of the front subframe as it gets lowered, and disconnecting the steering shaft. I think there is a diy on this site but a shop manual is really what you need. An extra set of hands really helps too.
Old May 24, 2012 | 03:33 PM
RoninS2k's Avatar
These two threads helped me out the most.
PM me or post in this thread and I will try to help anyway i can (just did this a month ago)
http://www.hondatuningmagazine.com/t...all/index.html
https://www.s2ki.com/s2000/topic/384...1#entry7560891
Old May 24, 2012 | 05:16 PM
p0staboy's Avatar
When i did mine i never touched the steering shaft.
OP do you have a hoist to do it on? I can't even picture doing this without the car being REALLY high off the ground. Before I did it I thought it was going to be a big pain but it wasn't that bad. Keep in mind I did mine on a hoist.
Old May 24, 2012 | 10:31 PM
CT_00_S2K's Avatar
Thanks guys i needed all the info i can get . Thanks for your support and knowledge . "LONG LIVE S2K ".
Old May 25, 2012 | 10:27 AM
99SH's Avatar
Also note that you can access the top 2 transmission bolts from under the hood. G'luck
fredh5062
Apr 21, 2017 12:55 PM
Eldest Son of S2K owner!
Apr 8, 2017 11:42 AM
s2000powered
Jul 6, 2013 08:16 AM
124Spider
Nov 8, 2007 01:23 AM
custom_bimmer
May 3, 2007 09:02 PM
