clutch slipping?
OK, I just took my 2000 nfr(45000 miles) out of storage and after a day of having it out I decided to get on it a little. At first I thought I was spinning the tires because I was going uphill and it was around 36 degrees out.The car was fine till Vtec, then it would jump right to redline with no power, same exact thing on the next shift. There was no burning smell or any smoke.The car runs great until I get on it. My first guess is that the clutch needs replaced. If anyone has any ideas I would appreciate it. Also if it is the clutch what should I replace it with and should I replace the flywheel, I want to keep the stock feel but would like more performance out of it. Totally lost!
2nd owner...bought it with 29000 miles on it two years ago...stock except for fipk and tp...how is the exedy oem replacement kit...the car is a dd and my wife insists on driving it once in a while so I want to keep the stock feel...and I want it to last another 45000...any suggestion
still on original at 115000 miles. I once had a leaky slave cylinder and it leaked into the bell housing and made the clutch slip like crazy. Slave cylinder quit leaking and clutch went back to perfect. You said it was slipping after you got it out of storage, was it fine before storage? because a clutch doesn't just go from perfect to slipping its @$$ off after sitting unless it fly's apart, or something leaks on it, or its over heated really bad, ect..
now I'm worried about taking into the shop and them just telling me that The clutch needs replaced(probably over 1000) and its just the slave cylinder...The shop I'm taking it to is the sponsor of clevelandracing.com and is pretty reputable in the area.
DUFFAA
Jun 15, 2015 02:46 AM
