Clutch smell sitting at a stop?
Old 05-29-2016, 09:59 PM
Soviet's Avatar
Originally Posted by Car Analogy
Originally Posted by Canadian_CD9A
The clutch has some play before it starts moving fluid, but I still can't gauge it properly. This isn't something I want to mess up.
If dealers up there are anything like down here, youd be less likely to screw things up than they would, even if you dont know which end of a wrench is which.
Im guessing they will give you some quote for $1k+ worth of work, which if you have them do, will result in them fixing nothing you are complaining about now, and potentially breaking a few new things. Potentially very expensive things. Which they will then blame on you. They are infallible experts, after all.
Sent from my SM-G920P using IB AutoGroup
this.
Old 05-30-2016, 04:25 PM
Canadian_CD9A's Avatar
I took a shot at adjusting it; even with the rod clocked to provide maximum play, I still got a bit of smell. Tightened up the play and got smell too. My rear center caps are hot so there is an ebrake issue, but the clutch is still suspect.
On another note, target acquired. Would this leaky SOB do it? Disregard the zoo animal that clearly lived under there at one point.
Old 05-30-2016, 09:50 PM
windhund116's Avatar
Received 1,439 Likes on 965 Posts
How's the tranny oil level? May have a main seal leak on tranny input or engine main dripping fluid onto clutch area. Fluid gets burnt -> smell.
flybikeslee
05-01-2018 01:01 AM
Sceanzo
05-15-2013 08:43 PM
heathas2k
09-24-2009 05:51 PM
2_and
06-18-2004 07:09 AM
Quick Reply: Clutch smell sitting at a stop?
