Code Diagnosing: Please help!
Old Jun 26, 2007 | 10:55 AM
jon3501447's Avatar
Thumbs up Code Diagnosing: Please help!
Ok guys, I
Old Jun 26, 2007 | 05:28 PM
jon3501447's Avatar
Ok people, i know someone out there is holding the answer. So I figure if none of you guys reply by tonight I'm going to go ahead and switch around a couple of the coil packs and see if the misfire in cylinder one jumps to another cylinder........hit me up guys
Old Jun 26, 2007 | 05:43 PM
weiRtech's Avatar
with what little mileage you have i'd point the finger first at a bad plug, but you changed them... pull them out and read them. then i'd go with your idea of moving the coil to a different cylinder. i can't see it being rings or a fuel injector or the ecu.
Old Jun 26, 2007 | 06:43 PM
heresnowhy's Avatar
I would switch injectors around. I have seen countless sets of injectors go bad on S's. Free to do, only takes a few extra mintues..... See if the misfire follows the bad injector.... Make sure not to pinch the o rings when you do it...
Old Jun 27, 2007 | 08:47 AM
jon3501447's Avatar
So this morning i went ahead and strategically switched a couple of the coil packs and reset the check engine light. Now I just have to play the waiting game and see what code(s) I get the next time the check engine light comes on......I hope it's just a bad coil...<fingers crossed>
suzuka_blue_s2k
Jun 18, 2018 08:45 AM
spinpio
Jan 11, 2008 01:04 PM
s2kbad
Feb 16, 2007 08:36 PM
s2konroids
May 30, 2006 05:06 AM
MyHieu
Sep 19, 2004 06:46 AM
