Code P0410
Old Aug 19, 2013 | 03:32 PM
BEASTMODE's Avatar
I also just got this CEL and found a bad fuse. Sucks that OP started with the expensive parts first!
Old Feb 27, 2014 | 04:56 PM
Vugie's Avatar
Mine just popped up a few days ago. What fuse are you guys talking about. Care to help please? Thanks.
Old Nov 25, 2014 | 09:28 AM
Bigave70's Avatar
I'm throwing the same p0410 but I also have a cold air intake that I just installed. Could that have anything to do with it? If not, what fuse are you guys replacing that is helping?
Old Nov 25, 2014 | 10:09 AM
CoolGuy094's Avatar
If you JUST installed the intake right before getting the code, then its likely you have some of your vacuum lines switched/connected in the wrong places. Check the diagram that (hopefully) came in the install instructions.
Old Nov 25, 2014 | 10:21 AM
1nate7's Avatar
This, and specifically make sure the check valve is installed for correct flow.
Old Nov 26, 2014 | 07:52 AM
Bigave70's Avatar
I actually bought the car with the intake already installed. There is no manual for it, I'm sure I could check online for one as still search for the things you guys have suggested. Where can I find the check valve ?
lotus7racer
Sep 21, 2012 09:37 AM
Dsteven21
Jan 23, 2012 05:54 AM
cpx3mbp
Jun 28, 2011 02:30 PM
gravitykills
Aug 28, 2008 06:34 PM
gravitykills
Aug 26, 2008 02:48 PM
