Code question
Old Dec 10, 2005 | 02:01 PM
adorkableguy's Avatar
Default Code question
I got a CEL code P1518? Know what it is? I started up my car this morning and the rpm was at 1500, usually it is suppose to be at 2000 at cold start up. I tried steping on the gas pedal trying to hold it at 3000rpm, but it kept reving up and down. First I thought it was a misfire, but wouldn't that make the CEL flash? So I disconnected the MAP sensor (while the car was off) and it fixed the problem, but I am just curious what code P1518 is.
Thanks
Old Dec 10, 2005 | 02:45 PM
xviper's Avatar
I see only one code in the 1500s in the Helm manual and that's P1519 and it's for Idle Air Control Valve.
Old Dec 14, 2005 | 05:29 PM
Yes, it is P1519, sorry heh.. Any idea how I can fix/repair this problem? I messed with the map sensor and it only fixed the problem for awhile. The light came back on again (after driving the car for 3 days). Are there any "recalls" for the map sensor if it is the problem?
Old Dec 14, 2005 | 06:02 PM
xviper's Avatar
There is a "TSB" for the MAP and securing system but this would not apply to your issue. The IAC valve has been reported as an issue. They should change it on warranty.
Laguna_S2K
Aug 28, 2014 10:01 AM
sybar
Oct 27, 2010 01:03 PM
s2kNORcali
Mar 18, 2010 11:36 PM
dryoung
Apr 7, 2008 03:06 PM
frycow
Jul 28, 2005 12:49 PM
