Coilover Install
Old Nov 23, 2004 | 12:13 PM
LudeAtic's Avatar
Default Coilover Install
Im about to purchase a set of Tein CS' for My04. I just need to know how to install them because im not too sure if i would understand the Tein instructions. Does anyone have a DIY instructions or a FAQ type of thing on this?
Old Nov 23, 2004 | 12:19 PM
dut's Avatar
dut
- pretty self-explanatory
Old Nov 23, 2004 | 01:03 PM
gfacter's Avatar
pretty self-explanatory...? Not really
I suggest you purchase a Honda Shop manual, that should cover most of the steps. It will give you all the torque values also.
Most everyone unbolts the upper A-arm mounts from the brackets instead of removing the ball joint.
Also you need to load the suspension before the final torquing of the bolts, I used a floor jack to jack up the lower A-arm.
Old Nov 29, 2004 | 10:04 PM
meth's Avatar
actually i am about to go and do mine also. i had an excellent one bookmarked, and i have been searching for days for it, lost the bookmark when i re-installed software.
if any of you have a good DIY i would also be interested. yes i have used the search function. type in coilover or coilover + install, a million irrelevant things get searched and everything gets listed by date modified and i know this DIY was from like 2 years ago.
thanks.
Old Nov 29, 2004 | 10:42 PM
papa5murf's Avatar
it's really simple..... quite explanitory... if you have any knowledge of suspension you can do it...
Old Dec 1, 2004 | 03:53 AM
Tinker219's Avatar
Why is this? I recently did a self-alignment, and noticed about 3/4" more wheel gap on my drivers front wheel than the rest of the wheels. I wonder if the torque from the bolts holds the LCA in position, which if the suspension is unloaded, holds the LCA lower...
Ill bust out my helms I just recieved yesturday
s2Y00
May 10, 2017 05:10 AM
06Estukay
Jun 7, 2011 12:01 PM
macr88
Suspension/Brakes
Jan 29, 2010 09:52 AM
Bobby_Digital
Jun 19, 2009 01:52 PM
LudeAtic
Jan 13, 2005 09:48 PM
