Coilover install
Old Sep 30, 2005 | 11:57 AM
ImportSport's Avatar
Originally Posted by RoaringVtec,Sep 27 2005, 01:42 PM
If i take it to a good alignment shop should the guy understand if i tell him i little more "aggressive" aligment? Thanks
This is not something that I would risk. Get your alignment specs from the boards and take in the exact measures that you want.
Old Oct 1, 2005 | 09:46 AM
RoaringVtec's Avatar
Question, i've dropped the car using coilovers. After install i measure and perfect according to my desire. Then i drive around the block once and all 4 corners are uneven by no more than 1/4". I precisely measure on the rear the coilovers to make sure the drop was exact. The front was the same measure same distance between perches to assure same drop. So i re-measure and adjust height again, then i drive around and damn the same crap. How long should i let the srpings settle before i take it to get aligned? Thanks and what are the oem alignment specs? Thanks a lot
w1ngt
Feb 18, 2009 10:39 AM
jdm jedi
Oct 1, 2007 11:23 PM
S2K626
Aug 8, 2007 10:23 PM
tenblade2001
May 14, 2003 06:34 AM
unregistered
May 9, 2003 10:27 AM
