cold start stall?
Old Jan 25, 2005 | 06:33 PM
natural's Avatar
Default cold start stall?
Ive recently been having some problems cold starting my S and i was wondering if anyone had any ideas about what might cause this problem. This problem started within the last week, when we in VA had a nice temp drop deep into freezing temps. Whenever i go to cold start my car, the car will start fine and begin to idle at around 2k rpm. However, about 5 seconds after it begins to idle, the rpms drop and the car stalls out. Now, when i go to start it again, it starts and idles fine just like it is suposed to. Like i said this only happens on cold starts where the car has been sitting for a few hours. Just wondering if anyone has a solution to this problem. I dont get any cels and the car drives just like normal after its started.
dan
Old Jan 25, 2005 | 06:51 PM
xviper's Avatar
This is a fairly common occurence and has been posted here lots. It's the ECU not being able to compensate for the climatic and environmental changes that usually occur this time of year. Let it die and don't help it by giving it gas. Hopefully, it will "learn" after a few episodes and in time, it won't do it anymore. Mine did this at the beginning of the first 3 winters. Then the 4th and 5th winter, it didn't do it at all. It had "learned".
However, just in case yours doesn't learn and there may be a real problem, do the MAP whack and ECU reset. If this fixes the problem, then I would suggest that you may be in need of a new MAP sensor and the new securing system that Honda has a TSB out on.
Old Jan 25, 2005 | 07:02 PM
natural's Avatar
cool, thank u sir. i was thinkin of doin the ecu reset.
dan
Old Jan 25, 2005 | 07:22 PM
silverstones2k1's Avatar
hey i'm from NY and it always does that... i got used to it and dont worry anymore.. first start okays.. then shuts off and then do it again and
Old Jan 25, 2005 | 10:02 PM
sr20de_f20c's Avatar
Try parking indoors, i have the same problem but my car is fine otherwise. it only happens when it's been outside, sitting, & it's really cold.
Old Jan 27, 2005 | 01:29 PM
Project SSAP1's Avatar
me too....im just used to it...im mad though caused i wanted to get an automatic starter but im affraid that it wotn work well in cold weather where i need it the most....i figure if i hit the button it will just shut off...
anybody here have remote start???
Old Jan 27, 2005 | 07:11 PM
daverx7's Avatar
This not just a S2000 thing as my '00 Prelude does the exact same thing in the very cold weather. I just let it die and start it right back up. So far, no problems, and it has 92K miles... If it were to be a problem, I would have expected to have busted by now.
-D
Old Jan 27, 2005 | 07:51 PM
Jaydem's Avatar
always happens to me as well!!! I guess its nothing to worry about!
Jay
driftintherain
Nov 24, 2008 11:39 AM
Moddiction
Dec 17, 2007 05:06 PM
Turtle636
Feb 1, 2007 06:35 PM
chowbj
Jan 17, 2007 09:35 AM
