Trouble with Cold start?
Old Jan 16, 2007 | 04:55 PM
chowbj's Avatar
Default Trouble with Cold start?
So I left my car outside while at work today in probably what was sub 30'c temps. When I came back at night to start it, the engine had a hard time getting started. It evenually didn't start, and I had to redo at which point it was all normal.
Does this ever happen to any of you winter drivers?
T hanks,
Old Jan 16, 2007 | 05:03 PM
jeggy's Avatar
Old Jan 16, 2007 | 05:33 PM
common reactor's Avatar
My car will sometimes act like it's not going to start, and then start. As weird as that sounds, when it's cold, the car will start to turn over...then start...then almost shut down and then start. My three friends that have S2K's have the same problem.
Old Jan 16, 2007 | 10:14 PM
blackout's Avatar
Same problem here. cept it dies on cold starts when the chill first sets in for a few days
Old Jan 16, 2007 | 10:27 PM
TitusS2k's Avatar
My car Starts right up when kept in the garage, when it sits out side it has no problems either- But when its cold out and im crusing around and when i come to a stop the rpm's will drop a little bit and feel like it will die... But thats MY00
Old Jan 17, 2007 | 09:08 AM
K-Lo's Avatar
on very cold mornings (lately) my car stalls on the first try starting it it's usually accompanied by a noisy squeal from what i believe is the serpentine belt.
Old Jan 17, 2007 | 09:35 AM
CKit's Avatar
If you're on your original battery, consider replacing it if the starter is slow to crank. Get a battery with enough CCA (cold cranking amps) and don't mess around with the little Hawker batteries if you're in a cold climate.
gbjhch9
Aug 31, 2014 10:23 AM
Moddiction
Dec 17, 2007 05:06 PM
Turtle636
Feb 1, 2007 06:35 PM
natural
Jan 27, 2005 07:51 PM
