Compression Check
Old Jan 29, 2007 | 06:13 PM
SilvCF2k's Avatar
Thumbs down Compression Check
I just completed a compression check with depressing results. Stock should be in 228psi +/- 28 max
First test DRY
#1 200
#2 195
#3 195
#4 195
Second Test WET (3 teaspoons of oil)
#1 280
#2 255
#3 270
#4 250
What do you think guys? Do you think it is bad rings? Where should I start with the diagnosises of this problem?
Old Jan 29, 2007 | 06:14 PM
SilvCF2k's Avatar
One more thing. I have 85,XXX miles.
Old Jan 29, 2007 | 06:23 PM
iDomN8U's Avatar
I don't think that's too bad... they look even which is the good news.
Old Jan 29, 2007 | 06:26 PM
SilvCF2k's Avatar
The +/-28 is what scares me since it is a bit low? Anyone know what I could do to maybe help this matter or do you think it is time to rebuild the engine?
Old Jan 29, 2007 | 06:31 PM
TitusS2k's Avatar
Boost it now since the compression is lower............ Im J.P
I dunno what to tell ya!
Old Jan 29, 2007 | 06:52 PM
iDomN8U's Avatar
I think that she has plently of life in her... drive it like its hot!
Old Jan 29, 2007 | 08:31 PM
s2k dre's Avatar
if it aint burning oil then i wouldnt worry at all.
Old Jan 29, 2007 | 09:46 PM
SilvCF2k's Avatar
well after a bit of research I found out that my compression is just fine. Sorry for this guys. Take care all!
Old Jan 29, 2007 | 10:01 PM
Greenlight's Avatar
Make sure and open the throttle body when checking the compression. Many people forget to do this and it can make a big difference.
Old Jan 30, 2007 | 09:13 AM
SilvCF2k's Avatar
135psi to 228psi is within the range. With a max veration BETWEEN cylinders of 28psi.
