Compression Check
Old Jan 30, 2007 | 05:46 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
to get numbers like 228...
Car must be hot, and just shut off.
Throttle at WOT.
Fuel pump disabled.
All plugs out.
Old Jan 30, 2007 | 07:38 PM
mxt_77's Avatar
That's my technique, and I get 240-255 every time.
With a cold engine (and all other variables the same), I still think I blow about 220-230psi, though.
Never tried adding oil to the mix, though.
Old Jan 30, 2007 | 07:41 PM
N/Apower's Avatar
240ish is what I have heard before from these cars. I PM'ed someone about it once. They got all 235 +- 5psi or something.
Old Jan 30, 2007 | 09:10 PM
dagostino777's Avatar
when should u get a compression check.. i have an ap2 with 13K miles... should i check it? or not neccesary?
Old Jan 31, 2007 | 05:50 AM
mxt_77's Avatar
You can do it any time you feel like it. I check mine fairly regularly because I drive the car hard and I've also done things to my engine that make me concerned about its health. (Plus, it takes all of 30 minutes to check it).
For a regular car, as long as you're not experiencing any problems and haven't abused the engine, you may never need to check compression... however, I'd do it ASAP just to get a baseline. Then check it maybe every 10-20K miles, especially if you drive the car hard.
That's just my opinion, though.
Old Jan 31, 2007 | 06:06 AM
dmw16's Avatar
Is there a how-to on compression checking?
Old Jan 31, 2007 | 06:38 AM
iluvs2ks's Avatar
I just got my AP2 and as soon as I get a chance I'm going to do a compression test on it. I have a 1993 civic si (which I'm going to sell) with the original motor SOHC Vtec and it has 123k miles. I did the compressino testr on it and it read 210 respectively. One or two I don't remember exactly were 209(motor been raced plenty). Your motor is much newer than the 14 yr old motor w/ less miles and IMO I would take to the dealr if you still got warranty and try to get a new motor idk try it. If my motor throws low #'s I'm definitely going to the dealer.
Old Jan 31, 2007 | 08:07 AM
CourageOO7's Avatar
lol...I wish my compression looked like that
Old Jan 31, 2007 | 08:44 AM
iluvs2ks's Avatar
were you reffering to my reply???? lol
Old Jan 31, 2007 | 09:56 AM
CourageOO7's Avatar
No, I was refering to the initial post.
