Compression Check
Old Jan 31, 2007 | 11:58 AM
  #21
iam7head's Avatar
Originally Posted by N/Apower,Jan 30 2007, 08:41 PM
240ish is what I have heard before from these cars. I PM'ed someone about it once. They got all 235 +- 5psi or something.
it varies with different gauges, adaptor, battery(some people hold charge while doing cranking for all four cylinder),etc
it's not how high the number but how little the number varies that indicats a problem.
and make sure you do all 4 cylinder with the same number of crank, repeat the testing process at least 3-4 time just to get a constant result.
plus you always gets a slightly lower number on brand new car, the number is higher when it's break it. the number could even higher when you get carbon deposite in the piston, etc.
Old Jan 31, 2007 | 12:22 PM
  #22
N/Apower's Avatar
Originally Posted by iluvs2ks,Jan 31 2007, 07:38 AM
I just got my AP2 and as soon as I get a chance I'm going to do a compression test on it. I have a 1993 civic si (which I'm going to sell) with the original motor SOHC Vtec and it has 123k miles. I did the compressino testr on it and it read 210 respectively. One or two I don't remember exactly were 209(motor been raced plenty). Your motor is much newer than the 14 yr old motor w/ less miles and IMO I would take to the dealr if you still got warranty and try to get a new motor idk try it. If my motor throws low #'s I'm definitely going to the dealer.
cam specs, static and dynamic compression, all play a role in compression numbers. While an S2000 may have 240psi/cyl, a stock 5.0 mustang will only have 150-170 psi/cyl and both cars be in optimum condition.
Old Feb 2, 2007 | 09:39 AM
  #23
SilvCF2k's Avatar
I did mine while it was hot, I didn't disable to fuel pump though. I will check it again soon and hopefully those numbers will be a bit better. Thx everyone.
Old Feb 2, 2007 | 03:46 PM
  #24
iluvs2ks's Avatar
LOL Idk how to QUOTE But N/A power thatnks for the tip I didn't think of that when I wrote that.
But also for example lets assume an s2000 should be well over 220 respectively. I know the variations between each cylinder is what you guide yourself on. But lets say you get 195 across the board. You got consistency but you have low numbers. I mean I would say somethings wrong....
Correct me if I'm wrong.
Also u cant compare my sohc to a f22 or f20 i understand and agree with you... but if for the sohc the highest is 220 (or a lil les) and im putting down 210 across then damn the motor is fine I would say..
But now you got the s2 with 195 or w/e then Im going to question myself on damn is this motor dying???? I dont know if im expressing myself right.....
Old Feb 3, 2007 | 03:46 AM
  #25
SilvCF2k's Avatar
I understand were you are going with that iluvs2ks. I am a bit nervous about my numbers and I will check again here VERY soon. The car is just sitting right now so I am not in a rush to do this. Also I am in the middle of adjusting the valves right now.
Old Feb 4, 2007 | 07:52 PM
  #26
iluvs2ks's Avatar
Well I wish you the best of luck and we'll hopefully hear from you soon. im new to this forum but i like the way ppl actually pay attention to others..... good luck once again
Old Feb 6, 2007 | 06:16 AM
  #27
snakeeater's Avatar
IMHO Your compression numbers look good for that mileage.
Sabre
Nov 9, 2015 01:09 PM
F20CZJ
Oct 31, 2015 05:32 AM
Ed'sS2000
Oct 23, 2014 07:25 AM
bakalag
Dec 11, 2009 01:07 PM
apex2k
Nov 10, 2004 03:42 PM
