compression test
Old Feb 29, 2008 | 03:00 PM
s2kbtos's Avatar
Default compression test
i just did the copression test on my s2000 and it came as this
1#195
2#180
3#178
4#178
this test was done when the car was cold and sitting at my garage for 2 days.
Old Feb 29, 2008 | 03:17 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Could be normal.
Do it hot the results will be very different.
Make sure:
-all plugs are out
-throttle is wide open
-fuel pump fuse is removed
iDomN8U's Avatar
run the car to normal operaturing temperature then try again
Old Feb 29, 2008 | 03:19 PM
FF2Skip's Avatar
Just like a dyno sheet, do not get hung up on the numbers by themselves. If you had a huge disparity between one cylinder and the rest, that would be of concern. Do as the above gents said and re-test.
Old Feb 29, 2008 | 03:21 PM
s2kbtos's Avatar
the plugs were out but i forgo to take out the fuse and i didn't press on the gas pedal. i will try to do it tomorrow.
Old Feb 29, 2008 | 03:53 PM
AP_ONE's Avatar
youll get a very different result and be happy you didnt give it gas then lol!
Old Feb 29, 2008 | 06:06 PM
Billman250's Avatar
Top Answer: 1
Not removing the fuse is NOT good (in other words, it's important to remove it)
If the fuse is left in, fuel is sprayed into the cylinder during cranking, washing the oil from the rings yielding lower comp numbers.
Old Mar 1, 2008 | 06:42 PM
s2kbtos's Avatar
ok guys! thanks! Bill!
you know i did the compression test today and i got
1#205
2#205
3#205
4#205
so i think the engine is pretty good!
Old Mar 4, 2008 | 07:50 PM
Apex_AP1's Avatar
what can cause a compression leak? and will any places do a on-the-spot compression test for free like a cel reading or battery check?
Old Mar 4, 2008 | 09:31 PM
jyeung528's Avatar
bad rings, bent valves or valve guides or seals...head gasket...etc.
dsddcd
Feb 20, 2019 03:31 AM
s2k0utlaw
Mar 23, 2013 01:04 PM
tone.101
May 7, 2012 04:17 PM
acn684
Nov 17, 2011 02:05 PM
Moddiction
Jun 20, 2008 08:53 AM
