Compression test was good, do I need to do a leakdown test as well?
Old May 13, 2014 | 09:08 AM
solitarycheese's Avatar
Default Compression test was good, do I need to do a leakdown test as well?
I did a compression test to diagnose a cylinder misfire problem. Compression was good, if a little high: #1 at 248psi, #2 at 241psi, $3 at 235psi, and #4 with 247psi (average of 3 test results). Tested warm, WOT. Also put in new spark plugs and swapped coil packs around to no avail.
With good compression results, would a leakdown test give any useful information?
Old May 13, 2014 | 12:38 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Yes, leakdown will show leakage that a compression test cannot.
Old May 15, 2014 | 12:21 PM
It's at the mechanic now. My solid CEL turned into a blinking CEL. Hope I didn't wreck anything with my shade tree wrenching.
Old May 16, 2014 | 05:36 AM
s2000maniac's Avatar
That means that it went from a radom mis fire to a major mis fire. See if your mechanic can Check out the fuel injectors.
Patrick L
Oct 18, 2017 07:51 AM
WarrenW
Jun 10, 2015 08:57 AM
kmengys2k
May 3, 2010 01:16 PM
Trigun
Oct 3, 2006 11:27 AM
