Compression test question
I go down this friday to check out/pick up the replacement engine I found. It's several hours away.
I'm pretty confident that it's going to be OK, but I want to be sure before I drop that much cash.
I'll be doing an out-of-car compression test and have done some reading up on it since I'd never done it before.
There are a couple of questions I have, to make sure I get it done right.
1) Oil - the engine has been sitting dry for a couple of years. Would doing a compression test as-is be OK or would it risk damage? Should I top it off with oil and manually turn it a bit to get oil through the system before I do any cranking?
2) Wet vs dry testing - With it sitting so long and being cold, I expect it to read lower than normal compression. I'm going to be looking for constancy rather than high numbers. That being said, am I better off leaving it dry or should I do a wet test by adding oil to the cylinders before I do the compression test?
Thanks guys!
Thanks guys!
chriss2kk
Mar 29, 2013 08:21 AM
mrkim019
Nov 28, 2005 10:02 AM
