knocking noise, is it LSD? Help needed
Old Nov 3, 2015 | 11:44 AM
leemaverickly's Avatar
Default knocking noise, is it LSD? Help needed
Hi folks, do you mind taking a look at my video? Is it normal to have this kind of clunk noise when I rotate rear wheel back and forth? https://www.youtube.com/watch?v=F0rt9LeyVwI
I first noticed I would hear a loud clunk after putting the car in reverse and backing up from the garage cold in the morning. Lately the car started to make single clunk noise from the rear when the weight suddenly shifts to the rear. I searched the forum and found a lot of posts describing similar problems. I know it could be rear caliper bolts, suspension, LSD, axle, wheel bearing, etc. So I am in the process of locating the problem. My axle nuts were retorqued so that can be ruled out.
My car is a 2001 and is totally factory.
Old Nov 7, 2015 | 05:12 AM
need help guys
Old Nov 7, 2015 | 06:38 AM
windhund116's Avatar
Kinda sounds like noise is coming from diff. Check the diff fluid recently? Much metal in oil?
Old Nov 7, 2015 | 12:21 PM
I changed diff fluid last year. I will do it again to see. Can you check if your car makes this noise when rotating the wheel by hand?
Thanks for your reply.
Old Nov 7, 2015 | 02:34 PM
Gonna try and adjust valves, in next couple of days. Will lift rear end and see what play, from the diff, I get.
Old Nov 8, 2015 | 11:50 AM
I appreciate it
Old Nov 9, 2015 | 03:11 PM
leemaverickly, ok did a valve adjustment, today. Afterwards, I lifted the rear and tried spinning the tires. Each side. With opposite side free and held. No clunking noise, at all. Really, a very smooth feel.
Sorry, about that.
KyungMin
Feb 13, 2014 04:13 PM
s2kbenztech
Tampa
Sep 22, 2009 01:54 PM
WayneS2
Dec 13, 2008 01:16 PM
Vladimir L
Jan 18, 2006 10:39 PM
Redline Drift
May 20, 2004 06:05 PM
