High compression results
Old Oct 18, 2011 | 07:49 PM
BEASTMODE's Avatar
Default High compression results
Did a compression test tonight and got 250, 245, 250, 260. I checked each cylinder twice to confirm. I haven't seen another engine test this high. Is it normal to have such high numbers on an engine with 125,000 miles?
Note: Forgot to depress accelerator during test. Can this cause high numbers?
Old Oct 18, 2011 | 08:04 PM
GrandMasterKhan's Avatar
mine read 225 per cyl with a 10.5:1 compression pistons. I also did not press the accelerator as my car is DBW it wouldnt matter if i did or not.
Old Oct 19, 2011 | 02:48 PM
andy_intel's Avatar
I did mine recently and got between 268 and 270 on all cylinders. Nice high numbers certainly aren't anything to worry about, as long as it's within reason. Another gauge might read 240 or even 220. Your numbers are pretty consistent across the cylinders so that's the most important thing, a healthy engine I would guess
Old Oct 19, 2011 | 09:01 PM
woodburn's Avatar
Looks good to me, last time I checked my compression was around the same numbers with an f22.
s2kbtos
Nov 8, 2015 11:06 PM
762
Nov 19, 2010 04:51 PM
s2kflorida
Jun 7, 2010 07:07 PM
Xherrox
Mar 21, 2009 04:56 PM
jert534
Jul 18, 2006 06:38 PM
