Compression test round two
I've moved out of Colorado, and was interested in doing a compression test closer to sea level. My results are as follows:
C1: 210, 210
C2: 240, 240
C3: 235, 235
C4: 235, 235
Should I be concerned about cylinder one?
C1: 210, 210
C2: 240, 240
C3: 235, 235
C4: 235, 235
When was your last valve adjustment? If you are really lucky, its just a valve lash issue, and you've caught it in time.
Otherwise you're hoping its a burnt calve, which can be cleaned up (need to remove head).
If you are not lucky, its rings
Leakdown will tell you. But if its been a while since valve adjustment, I would start with that, then redo compression test. For me that would be easier than leakdown because I don't have the equipment for that.
Thanks for the replies. Last valve adjustment was done by me but it was also my first ever attempt at it. That was about 5 months ago.
I dont have access to compressed air, so will prolly have the dealer I work at give it a shot.
Asked our certified Honda mechanic who has been working on Hondas for years (at Honda dealers only) if he would run a leak down and he was pretty confident in saying "It's fine, don't worry so much."
So I will ask one last time just to be safe -- is it worth worrying about, or is he right? As long as its not actually showing any issues (like down on power or misfires) stop being so worried.
Car has 66k miles.
Car has 66k miles.
