Leak down test problems
Old Jul 28, 2014 | 04:19 PM
boyguan's Avatar
Default Leak down test problems
So I did a compression test on my car a while ago with 210/210/200/170. I finally got around to trying a leak down test but no matter what it seems like will not go past 70 percent. It always seems like it's leaking from the intake side
I put a rod in the cylinder and turn it until it reaches the maximum height. Plug in the tester and it shows 50-70 sometimes even 30. I rotate it once more and so the rod is up and sometimes it's better.
I always thought that the valves would be closed if the piston was up?
Old Jul 28, 2014 | 04:46 PM
jkelley's Avatar
They are supposed to be seated when piston is at TDC. Perhaps this is pointing you to your issue. Bent/burnt valve?
Old Jul 28, 2014 | 04:54 PM
starchland's Avatar
Why are we jumping to valve problems? What did the valve adjustment reveal?
Old Jul 29, 2014 | 12:16 AM
boyguan's Avatar
My car drives and idles great. I track it with no issues or noise
I tried a leak down on all the cylinders and same crap results
I did the valve adjustment myself and they are fine with no noise
Old Jul 29, 2014 | 03:10 AM
bgoetz's Avatar
Why did you check the compression and decide to do a leak down? Was there am "event" that gave you concern? 170 on cylinder 4 is no good, depending how you did the compression test I would say all of those #s seem low. The leak down is failing for a reason. Provide more history, milage, AP1/2, any previous issues/incidents that may lead to a problem.
Old Jul 29, 2014 | 04:44 AM
jkelley's Avatar
I'm sorry, it was was tired last night and I think I assumed that with a leakdown that you would typically do a compression then move to valve adjustment then if that didn't workm, a leakdown which signalled to me that something bad was going on. Was not a correct train of thought. I apologize for my stupid assumption/repsonse lol.
Old Jul 29, 2014 | 05:31 PM
starchland's Avatar
Just working through the cheaper options it will hopefully turn out to be thumbs up
Old Jul 29, 2014 | 09:32 PM
boyguan's Avatar
I did a valve adjustment and a compression test. Found cylinder 4 low. Tracked a bunch of times and finally got around to trying a leak down test. The car is a 04 with 140k.
Backmarker
Sep 21, 2016 03:59 PM
vtecchris21
Jul 11, 2012 04:29 AM
Jacksparrow
Sep 17, 2008 04:13 AM
